TIG CARBON STEEL 11GA OUTSIDE CORNER STEEL 1F .045" FILLER ROD
scroll down for settings
METAL TYPE = CARBON STEEL
THICKNESS = 11GA
WELD TYPE = Fillet weld
JOINT TYPE = CORNER JOINT
POSITION = 1f FLAT
AMPERAGE = MACHINE SET TO 85-105 AMPS
FILLER WIRE = .045” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = MANUAL
POST FLOW = 8 SEC
TIPS: KEEP A TIGHT ARC
