TIG CARBON STEEL EDGE BEAD .050" THICK RULE OF 33 PULSE SETTINGS
METAL TYPE = carbon steel
THICKNESS = .050”
WELD TYPE = SURFACE EDGE BEAD
JOINT TYPE = EDGE BUILDUP
POSITION = FLAT
AMPERAGE = MACHINE AMPS SET TO 50 AMPS AND CONTROLLED WITH FOOT PEDAL (WITH PULSER ON,SETTING AMPS TO SAME AS WALL THICKNESS IS A GOOD RULE OF THUMB)
FILLER WIRE = 1/16” ER70S6
GAS FLOW = 20=25 CFH argon
CUP SIZE = 10
PRE FLOW = .2 SEC
POST FLOW = 10 SEC
ADDITIONAL SETTINGS = PULSE SETTINGS 33 PPS, 33% BACKGROUND, 33% ON TIME (RULE OF 33 FOR PULSE0
TIPS: KEEP A TIGHT ARC
Aim for an arc length that is equal or less than the diameter of your tungsten electrode. Torch angle can be forgiving provided your arc length is tight. Keep the hot tip of the filler wire shielded by the argon envelope from the tig cup Snip oxidized tip of filler metal before a restart
