TIG WELDING CARBON STEEL TUBING .055" BUTT
METAL TYPE = CARBON STEEL
THICKNESS = .055"
WELD TYPE = groove weld
JOINT TYPE = BUTT JOINT
POSITION = 1G FLAT
AMPERAGE = 55-60 amps
FILLER WIRE = .045” ER70S6
GAS FLOW = 20-25 CFH argon
CUP SIZE =  12
 PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
