TIG WELDING TIP-HOLD A TIGHT ARC
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = CARBON STEEL
THICKNESS = 5/8"
WELD TYPE = Fillet weld
JOINT TYPE = TEE JOINT
POSITION = 2F HORIZONTAL
AMPERAGE = MACHINE SET TO 160 AMPS CONTROLLED WITH PEDAL
FILLER WIRE = 1/16” ER70S6
GAS FLOW = 20 CFH argon
CUP SIZE = 8
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: 3 BIGGEST MISTAKES ARE TOO LONG AN ARC, TOO MUCH TORCH ANGLE, AND NOT SHIELDING THE HOT TIP OF FILLER ROD.
SO KEEP A TIGHT ARC
var l = window.location.href,
d = document;
