3/32" 6011 welding rod come in clutch in all kinds of situations.
One great example is when you need to make a quick weld repair and all you have available is 110volt power.
3/32" 6011 will run well at 75-85 amps and for most small inverter welders that run off either 110 or 220 volt power, 75-85 amps will allow burning a whole rod without popping a breaker.
6011 rods are the cousin of 6010 welding rods. Almost identical in mechanical properties but they are designed to run on A/C as well as DC welding current.
6011 rods are great all purpose rods for general repair and fabrication. A lot of people are not aware that 6011 3/32 welding rods are also available. You can even get 1/16 6011 rods if you shop online or a a store like harbor freight.
1/16 6011 rods are really useful for 2 things:
1. Welding thin sheet metal, like auto body work. Seriously, they are as good as a flux core 115 volt MIG welder,(if you are pretty good at Stick welding)
2. They are also really good if your Arc welder is a little on the wimpy side. Like an Arc welder that runs on 115 volts. The 1/16 6011 rods start easier and weld sheet metal much easier than the bigger diameter 6011 rods.
Something else that comes to mind is 5/32 6011 rods.
A Lincoln 225 amp buzz box is perfectly capable of burning 5/32 rods.
I welded a metal rack once with nothing but a Lincoln A/C 225 buzz box and some 5/32 6011 welding rods. The metal had been sitting outside and was rusty and about 3/8 thick. Those 5/32 6011 rods penetrated thru the rust easily and made some really decent looking welds.
Years later, that metal rack is still holding about 6000 pounds of metal bar stock in a machine shop.
Now remember, 6011 rods will not be as pretty as 6013. I take heat for this on occasion but I just do not like 6013 rods. Sometimes they work great, but other times they fool you and you have a line of slag right down the middle of the bead. I would rather have rough ripples and a good bead every time. That is why I prefer 6011.
leave this page on 6011 welding rods and see more stick welding tips
Not seeing what you searched for? The best way to find something on this site is to use this Search Tool.
Custom Search
It comes down to the flux coating composition and how that coating interacts with the arc and current flow. Here's a clear explanation:
🔌 6010 vs. 6011: Why One Works on All Polarities and the Other Doesn't
⚙️ Basic Difference:
🔬 The Role of the Flux Coating
Both rods are in the "60XX" family and produce strong welds with deep penetration. But the flux coating is what determines how they handle electrical current.
🔴 6010 – DC Only (Usually DC+ / DCEP but there are also weld procedures that call for DCEN)
👉 When you try to use 6010 on AC:
⚪ 6011 – All Polarities (AC, DC+, DC−)
👉 So with 6011:
💡 Why It Matters
Yes, there are some pipe welding procedures that use 6011 welding rods, but they are generally limited to non-code, low-pressure, or temporary applications.
✅ When 6011 Is Used in Pipe Welding:
🔧 1. Farm, Ranch, or Rural Piping
🔧 2. Field Repairs
🔧 3. Non-Code Utility Work
⚠️ When 6011 Is Not Used:
❌ Code Welding or High-Pressure Pipe
🧪 Why 6011 Isn’t Code-Approved:
