Arsenal Kit 2.0 TIG welding kit for Carbon, 4130, Stainless, Inconel, aluminum, and Titanium
Scroll down for Videos
4130-cluster-weldmonger-arsenal-kit
See the latest TIG Welding Videos here
ar·se·nal = a collection of weapons
We named this kit "Weldmonger Arsenal kit" because by definition its a collection of weapons that will help you get the most out of your TIG welding skills.
You have probably seen me use the clear #8 cups in several videos and you might have noticed how the puddle, and surrounding area are clearly visible.
8 pro clear cup really lights things up for better visibility
8-pro-lights-things-up
That’s because the clear #8 pro really lights things up.
At my age, that’s a big help.
The Furick Jazzy 10 ceramic cup is a real difference maker without requiring a lot of argon. I usually use 20 cfh with the jazzy.
jazzy-10-and-diffusers
The Furick 12 ceramic lets you maintain excellent argon shielding even with a really long stick out for those tight angles and down in holes.
fupa12-ss-coped
The BBW clear cup with brass insert gives you a big edge when it comes to chromoly, inconel, stainless, titanium, and all other superalloys used in motorsports and aerospace.
bbw-clear-sg19-with-diffusers
furick bbw cup titanium bike hub zank
We also added #4 thru #8 ceramic cups that work great with the Furick 3/32” gas lens setup included in the kit.
arsenal-4thru8ceramic
Because there are times when are low on Argon but you still need to get a job out the door on a Sunday afternoon when the welding supply is closed.
A TIG kit like our Weldmonger Arsenal Kit is the most convenient way to have a cup for any situation but also to  make sure all cups and hardware work with each other.
Hunting part numbers for collets and gas lenses to fit your torch is not the best use of your time so we did all that for you.
