Procedures for Socket Welds
This first video shows settings and technique for a 1-1/2" sched 40 socket weld
visit main socket weld page
If you are searching for a procedures for socket welds, I hope this page helps.
While we don't have official welding procedures for socket welds here, this page should help you get started in writing your own procedure for socket welds.
METAL TYPE = CARBON STEEL
THICKNESS = WALL THICKNESS 1/4”
WELD TYPE = Fillet weld SOCKET WELD
JOINT TYPE = SOCKET WELD
POSITION = IN VISE 2F HORIZONTAL
AMPERAGE = 120 AMPS
FILLER WIRE = 3/32” ER70S2
GAS FLOW = 20CFH argon
CUP SIZE = 8
ADDITIONAL SETTINGS = LIFT ARC
PRE FLOW = TORCH VALVE
POST FLOW = TORCH VALVE
TIPS: Aim for an arc length that is equal or less than the diameter of your tungsten electrode.
Torch angle can be forgiving provided your arc length is tight. Keep the hot tip of the filler wire shielded by the argon envelope from the tig cup SNIP THE END OF WIRE EVERY RESTART
Procedures for Socket welds - Carbon steel fitting welded to stainless pipe - cover pass
Gas lens kit used in video
Our new LArge Diameter Gas lens kit now comes with 5/32" setup for those high amperage jobs
large diameter gas lens close up
METAL TYPE = CARBON STEEL TO STAINLESS
THICKNESS = WALL THICKNESS 1/4”  ( 2 INCH SCHED 40)
WELD TYPE = Fillet weld  SOCKET WELD 3RD PASS COVER PASS
POSITION = TURNTABLE
AMPERAGE = 140 amps
FILLER WIRE = 1/8” ER309
CUP SIZE =  8
ADDITIONAL SETTINGS =  PRE FLOW = .5 SECPOST FLOW = 11 SEC
TIPS: KEEP A TIGHT ARC
