SELF SHIELDED FLUX CORE NR 211 CARBON STEEL 1/8" THICK VERTICAL FILLET WELD
Lincoln NR211 self shielded flux core wire is a E71T-11 class flux core wire that is not recommended for certain seismic applications or for multiple pass welds.
NR211 is fine for stuff like galvanized fencing or general light duty stuff
But a better choice for multiple pass welds would be Hobart Fabshield 21b.
WELD PROCESS = SELF SHIELDED FLUX CORE
METAL TYPE = CARBON STEEL
THICKNESS = 1/8""
WELD TYPE = Fillet weld
JOINT TYPE = TEE JOINT
POSITION = 3f vertical uphill
VOLTS = 18-19volts
WIRE SPEED = 216 IPM
WIRE SIZE = .035” LINCOLN NR211
GAS FLOW = N/A
CTWD (STICKOUT) = 3/4”
FILLER METAL = LINCOLN NR211 .035"
TIPS: A longer stickout aka contact to work distance CTWD of 3/4” provides best results
