THICKNESS = 6 inch schedule 80 pipe wall thickness .430"
WELD TYPE = groove open butt
JOINT TYPE = BUTT WELD OPEN ROOT WITH 5/32” GAP AND ZERO LAND
POSITION =jackstands
AMPERAGE = 80-85AMPS
FILLER WIRE = 1/8” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE = 8
PRE FLOW = MANUAL TORCH VALVE
POST FLOW = MANUAL TORCH VALVE
Aim for an arc length that is equal or less than the diameter of your tungsten electrode. Torch angle can be forgiving provided your arc length is tight. Keep the hot tip of the filler wire shielded by the argon envelope from the tig cup Snip oxidized tip of filler metal before a restart
Whether you are a student, hobbyist, or a working welder who wants to sharpen up, you can take a free trial and even get 25% off your first 3 months with promo code QS25.
