TIG CARBON STEEL 11GA LAP JOINT AND RESTARTs
Making a good smooth restart is fundamental to tig welding as well as all other types of welding.
Lets face it, you are going to run out of rod, or need to sneeze, or whatever and you will need to make a restart.
And if you can make a restart where you can't even tell where you restarted, then you are freed up to weld the thing however you need to.
METAL TYPE = CARBON STEEL
THICKNESS = 11GA
WELD TYPE = Fillet weld
JOINT TYPE = LAP JOINT
POSITION = 2f HORIZONTAL
AMPERAGE = MACHINE SET TO 100-125 AMPS CONTROLLED WITH PEDAL  115 AMPS SWEET SPOT
FILLER WIRE = 1/16” ER706
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC ..practice restarts until they blend in
tig welding carbon steel
