TIG CARBON STEEL FLASH TACKS 18 GA LAP JOINT
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = CARBON STEEL
THICKNESS = 18 GA
WELD TYPE = FILLET LAP FLASH TACKS
JOINT TYPE = LAP JOINT
POSITION = 2f HORIZONTAL
AMPERAGE = 80 amps with foot pedal
FILLER WIRE = NONE
GAS FLOW = 10 CFH argon
CUP SIZE = 5
PRE FLOW = .5 SEC
POST FLOW = 3 SEC
TIPS: PROP CUP ON LAP JOINT WITH SHORT STICKOUT.
ROCK CUP IN TO TOUCH ELECTRODE TIP AND BACK OFF JUST ENOUGH TO GET AN ARC.
TAP FOOT PEDAL TO MAX AMPS QUICKLY MAKING SURE THAT THERE IS ZERO GAP IN THE LAP JOINT.
OR USE A TORCH SWITCH...OR SET MACHINE TO PANEL AMPS SO THAT FOOT CONTROL IS A SWITCH.
var l = window.location.href,
d = document;
