METAL TYPE = CARBON STEEL
THICKNESS = 11GA
WELD TYPE = Fillet weld
JOINT TYPE = TEE JOINT
POSITION = 2f HORIZONTAL
AMPERAGE = 131 amps (PULSING WITH FOOT PEDAL AND MAXING OUT AT 131)
FILLER WIRE = 1/16” ER70S6
GAS FLOW = 20 CFH argon
CUP SIZE = 8
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC , WHEN I WAS PUMPING THE FOOT PEDAL, I WAS MAXING OUT AT 131 AMPS
Whether you are a student, hobbyist, or a working welder who wants to sharpen up, you can take a free trial and even get 25% off your first 3 months with promo code QS25.
