TIG 4140 1/4" THICK TO CHROME VANADIUM SOCKET HAST W FILLER
Did you know?...
*** We have a New TIG course learning system over at welderskills.com designed to help you learn faster, with less frustration, and with less metal.
***And that you will get Free Access to this $99.99 TIG course... included as part of your membership?
***And that if you use promo code QS25 you will get 25% off your first 3 months after your Free 7 day Trial?
***Its Easy to sign up
METAL TYPE = 4140 chromoly tube and chrome vanadium socket
THICKNESS = .250”
WELD TYPE = FILLET
JOINT TYPE = TEE JOINT
POSITION = 2F
AMPERAGE = 80-100 amps with foot pedal
FILLER WIRE = .063” hastelloy W
GAS FLOW = 20 CFH argon
CUP SIZE = 8
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
Snip oxidized tip of filler metal before a restart.
HASTELLOY W IS ALSO KNOWN AS AMS5786
