TIG WELDING CARBON STEEL 11GA COLD ROLLED LAP 2F
METAL TYPE = CARBON STEEL
THICKNESS = 11GA
WELD TYPE = Fillet weld
JOINT TYPE = LAP JOINT
POSITION = 2f HORIZONTAL
AMPERAGE = 117 amps
FILLER WIRE = 1/16” ER70S6
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
