TIG WELDING CARBON STEEL 11GA THICK EDGE BEAD PULSE SETTINGS
METAL TYPE = carbon steel
THICKNESS = .125”
WELD TYPE = SURFACE EDGE BEAD
JOINT TYPE = EDGE BUILD
UPPOSITION = FLAT
AMPERAGE = MACHINE AMPS SET TO 130 CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 1/16” ER70S6
GAS FLOW = 25 CFH argon
CUP SIZE =  12
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
ADDITIONAL SETTINGS =  PULSE SETTINGS 50PPS, 33% BACKGROUND, 33% ON TIME
TIPS: KEEP A TIGHT ARC
Aim for an arc length that is equal or less than the diameter of your tungsten electrode.Torch angle can be forgiving provided your arc length is tight.Keep the hot tip of the filler wire shielded by the argon envelope from the tig cupSnip oxidized tip of filler metal before a restart
