TIG WELDING CARBON STEEL .120" wall DOM TUBING
scroll down for settings
METAL TYPE = CARBON STEEL
THICKNESS = .120"
WELD TYPE = FILLET
JOINT TYPE = COPED TUBE JOINT
POSITION = FLAT
AMPERAGE = 120 amps with foot pedal
FILLER WIRE = .045” ER70S2
GAS FLOW = 20 -25 CFH argon
CUP SIZE =  10
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
Snip oxidized tip of filler metal before a restart
