TIG WELDING CARBON STEEL 5/8" thick FILLET WELD AT 140 AMPS
Scroll down for settings
METAL TYPE = CARBON STEEL
THICKNESS = 5/8"
WELD TYPE = Fillet weld
JOINT TYPE = TEE JOINT
POSITION = 2F HORIZONTAL
AMPERAGE = MACHINE SET TO 140 AMPS CONTROLLED WITH PEDAL  BUT MAXED OUT SOMETIMES
FILLER WIRE = 1/16” ER70S6
GAS FLOW = 20 CFH argon
CUP SIZE =  8
ADDITIONAL SETTINGS =   PRE FLOW = .5 SECPOST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
Keep the hot tip of the filler wire shielded by the argon envelope from the tig cup.
IF tip of rod gets oxidized, snip before restart
