METAL TYPE = CARBON STEEL
THICKNESS = 5/8" to 1/4"
WELD TYPE = Fillet weld
JOINT TYPE = TEE JOINT
POSITION = 2F HORIZONTAL
AMPERAGE = MACHINE SET TO 170 AMPS CONTROLLED WITH PEDAL BUT MAXED OUT SOMETIMES
FILLER WIRE = 3/32"” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE = 8
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
