TIG WELDING ON DISSIMILAR OR UNKOWN STEEL - SNAP ON WRENCH TO 4140
METAL TYPE = CHROMIUM VANADIUM STEEL TO 4140
THICKNESS =  1/4"
WELD TYPE = FILLET WELD
JOINT TYPE = BUTT
POSITION = FLAT
AMPERAGE = MACHINE SET TO 140  AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = .063” HASTELLOY W (AMS5786)
GAS FLOW = 20-25 CFH argon
CUP SIZE =  12
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
