Tig Walking the Cup Stainless to Carbon Steel pipe 3" sched 40 .300" wall
Large diameter gas lens kit with genuine CK parts...
Click on pic below to learn more
Our new LArge Diameter Gas lens kit now comes with 5/32" setup for those high amperage jobs
large diameter gas lens close up
scroll down for settings
METAL TYPE = carbon steel PIPE TO STAINLESS FLANGE
THICKNESS = 3 inch  SCHED 40 PIPE .300" wall
WELD TYPE = groove
JOINT TYPE = BUTT WELD
POSITION =   ROLLED IN JACK STANDS
AMPERAGE = 105-125 AMPS
FILLER WIRE = 1/8” ER309L
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW =  MANUAL
POST FLOW =  10
ADDITIONAL SETTINGS =   ARGON PURGE AT 25CFH REDUCING TO 10 CFH AT THE END
TIPS: EXTEND ELECTRODE ENOUGH TO GET A DECENT ANGLE SO THAT WALKING THE CUP OR FREEHAND WELDING BOTH WORK WELL …
