Tig Welding Stainless to Carbon socket weld root 1/4" wall thickness with 309L rod
This Large Diameter Gas lens kit for 17,18, 26 style torches is great for walking the cup on pipe
Our new LArge Diameter Gas lens kit now comes with 5/32" setup for those high amperage jobs
large diameter gas lens close up
scroll down for settings
METAL TYPE = CARBON STEEL TO STAINLESS
THICKNESS = WALL THICKNESS 1/4”  ( 2 INCH SCHED 40)
WELD TYPE = Fillet weld  SOCKET WELD root
JOINT TYPE = SOCKET WELD
POSITION = TURNTABLE
AMPERAGE = 140 amps
FILLER WIRE = 3/32” ER309
GAS FLOW = 15-20CFH argon
CUP SIZE =  6
ADDITIONAL SETTINGS =  PRE FLOW = .5 SECPOST FLOW = 11 SEC
TIPS: KEEP A TIGHT ARC
tig socket weld
