TIG WELDING TURNTABLE WELD 309 1/16" FILLER
primeweld 225 tig with stuff
The problem with most other really affordable tig welders is usually a really cheap foot pedal and TIG torch.  Primeweld went to extra expense to include a genuine CK17 torch with superflex hose along with a very smooth SSC style foot pedal.
A high quality CK dinse adapter is also included so that you can easily swap out a tig torch or cable when the time comes.
Primeweld also has a responsive primeweld equipment users group on facebook and also has demonstrated great customer support
Watch some more primeweld videos and you will see what I mean.
METAL TYPE = HIGH STRENGTH STEEL TO 304L STAINLESS STEEL THICKNESS = 3/4' TO 1/4"
WELD TYPE = FILLET
JOINT TYPE = TUBE TO PLATE
POSITION = TURNTABLE
AMPERAGE = MACHINE SET TO 150 AMPS CONTROLLED WITH FOOT PEDAL
TUNGSTEN = 2% LANTHANATED, 3/32" FILLER WIRE = 1/16"” ER309L POLARITY = DCEN
GAS FLOW = 25 CFH argon
CUP SIZE = 12
PRE FLOW = .2 SEC
POST FLOW = 11 SEC TIPS: GET COMFORTABLE AND PROP
Aim for an arc length that is equal or less than the diameter of your tungsten electrode. Torch angle can be forgiving provided your arc length is tight. KEEP HOT TIP OF WIRE SHIELDED IN ARGON. SNIP WIRE IF DISCOLORED
