MIG WELDING CARBON STEEL 2f tee
primeweld mig 180 stuff
primeweld mig 180 plugged into 115 volt power
Mig welding overhead with a primeweld mig 180
mig-welding-overhead-primeweldmig180-thumb
Mig Welding vertical Uphill settings
scroll down for settings
THICKNESS = 1/4” .250, 6mm
WELD TYPE = Fillet weld
JOINT TYPE = tee joint
POSITION = 2F, horizontal
VOLTS = 20 volts
WIRE SPEED = 333 IPM
WIRE SIZE = .035"
GAS FLOW = 20-25 CFH C25 GAS
CTWD  = 3/8”-1/2"
FILLER METAL = ER70S6
TIPS:A relatively short stickout aka contact to work distance CTWD of 3/8” to 1/2" makes a big difference.The technique shown is simple series of V shapes that traces the leading edge of the puddle
