STICK CARBON STEEL 7018 3/16" ELECTRODE FILLET WELD 2F
METAL TYPE = CARBON STEEL A36
THICKNESS = 1"
WELD TYPE = Fillet weld MULTI PASS
JOINT TYPE = TEE/LAP
POSITION = 2F
AMPS = 230 AMPS
ELECTRODE = 7018 3/16"
ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
