STICK WELDING CARBON STEEL 3/8" PLATE OVERHEAD 5/32 7010 HOT PASS
scroll down for settings for 5/32" 7010 hyp hot pass
METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE WELD HOT PASS
JOINT TYPE = BUTT
POSITION = 4G OVERHEAD PLATE
AMPS = 135-140 AMPS
ELECTRODE = 7010 5/32"
TIPS: WHIP AND PAUSE TECHNIQUE TO CONTROL PUDDLE
DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.
