STICK WELD UPHILL CARBON STEEL 3/8" WITH 5/32" 7018  RODS 3F TEE
If you need to pass a structural weld test, sometimes 5/32" 7018 uphill  is specified so I hope this video helps
scroll down for settings
METAL TYPE = CARBON STEEL A36
THICKNESS = 3/8"
WELD TYPE = Fillet weld
JOINT TYPE = TEE
POSITION = 3F VERTICAL UP
AMPS = 140 AMPS
ELECTRODE = 7018 5/32"
AMPERAGE SHOWN SHOULD GET YOU IN THE BALL PARK.
TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION.
FOR THIS WELD ARC FORCE WAS SET HIGH TO ALLOW USING FAIRLY LOW AMPERAGE FOR A 5/32" 7018
