STICK CARBON STEEL 1/4" THICK
7018 1/8" rod PADDING BEADS
Padding beads is one of the best ways to get consistent.
With very little metal and time spent prepping metal, you can get lots of hood time.
METAL TYPE = CARBON STEEL
THICKNESS = 1/4"
WELD TYPE = SURFACE
JOINT TYPE = PADDING BEADS
POSITION = FLAT
AMPS = 125-130 AMPS
ELECTRODE = 7018 1/8” EXCALIBUR
125 AMPERAGE SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
