STICK WELDING CARBON STEEL 7024 3/16" FLAT BEAD
METAL TYPE = CARBON STEEL
THICKNESS = 11GA
WELD TYPE = Fillet weld
JOINT TYPE = CORNER JOINT
POSITION = 2f HORIZONTAL
AMPERAGE = MACHINE SET TO 100-125 AMPS CONTROLLED WITH PEDAL  TUNGSTEN = 2% LANTHANATED, 3/32"
FILLER WIRE = 1/16” ER70S6
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
