STICK WELDING CARBON STEEL 4F OVERHEAD TEE 5/32" 7018
We got some requests for 5/32" 7018 from welders who are being required to weld with 5/32" 7018 overhead.
scroll down for detailed settings for overhead 5/32" 7018
METAL TYPE = CARBON STEEL A36
THICKNESS = 3/8"
WELD TYPE = Fillet weld MULTI PASS
JOINT TYPE = TEE
POSITION = 4F OVERHEAD
AMPS = 165 AMPS
ELECTRODE = 7018 5/32"
ADDITIONAL SETTINGS = ARC FORCE SET TO 10
ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
