STICK WELDING CARBON STEEL 3/8" PLATE 6010 ROOT AND 7010 3/16" rod DOWNHILL CAP
scroll down for settings FOR downhill 3/16" 7010 cap
METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE WELD  COVER PASS
JOINT TYPE = BUTT
POSITION = 45 DEGREE DOWNHILL PLATE
AMPS = 145-155 AMPS
ELECTRODE = 7010 3/16"
TIPS:   DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.
DEMONSTRATED AMPERAGE SHOULD GET YOU IN THE BALL PARK.
