What is the Best TIG Accessory Kit for your Type tig Torch and Application?
Watch the latest welding videos at Weldmonger.com
TIG-PRO-KIT-DRAWER-TEXT
tig-torches-and-cups-thumb
The very first upgrade I recommend for your 17 style tig torch is our stubby gas lens tig accessory kit
The Swiss Army Knife of TIG accessory kits is our Weldmonger TIG Pro Kit
whether you are tig welding square tubing, 4130 chromoly tubing, stainless sanitary tubing, aluminum, or titanium, our tig pro accessory kit has a cup that will handle the job.
TIG pro kit for 17 style tig torches
tig-pro-17
tig-pro-9-20
TIG pro kit for 9/20 style tig torches
The great thing about a TIG accessory kit is that once you know what type TIG torch you have, all you need to do is order the right kit for your torch and you can be sure everything will fit without wasting time looking up 20 different part numbers.
The best way to know what style TIG torch you have is to check out the collet body
identify-tig-torch-collet-bodies-weldmongerstore
If you are still in doubt this video should help
All of our TIG kits come in 2 versions
1. 17,18,26 style Torch
2. 9,20 style Torch
If your collet body is almost 2 inches long like the pic below, then your torch is a 17,18, or 26 style tig torch
If your collet body is less than 1 inch long like the pic below then your tig torch is a 9/20 style torch.
9 20 tig torch collet bodies
The Navigator TIG kit comes in both clear and ceramic cup versions
Here's whats Included in the Clear Navigator kit for 17,18,26 style torches
  • 1 - Weldmonger #4 Pink Cup
  • 1 - Weldmonger #5 Pink Cup
  • 1 - Weldmonger #6 Pink Cup
  • 1 - Weldmonger #7 Pink Cup
  • 1 - Weldmonger #8 Pink Cup
  • 1 - Furick #7 PRO clear Cup
  • 1 - Furick #8 PRO clear Cup
  • 1 - Furick Jazzy 10 clear Cup
  • 1 - Furick FUPA 12 clear Cup
  • 1 - Furick 3/32 Gas Lens for 17/18/26 Torches
  • 1 - Furick 3/32 Wedge Collet for 17/18/26 Torches
  • 1 - Furick Teflon Insulator for CK Torches
  • 1 - Furick Teflon Insulator for NON CK Torches
  • 1 - CK Worldwide Small Backcap
  • 1 - CK Worldwide Medium Backcap
  • 1 - CK Worldwide Large Backcap
  • 1 - Weldmonger 2% Lanthanated Tungsten Size 3/32
  • 1 - Spare O'Rings
  • 1 - Flambeau Made In The USA Tackle box
navigator-ceramic-17-torch
The Ceramic Version for 17,18,26 style torches includes
  • 1 - Weldmonger #4 Alumina Cup
  • 1 - Weldmonger #5 Alumina Cup
  • 1 - Weldmonger #6Alumina Cup
  • 1 - Weldmonger #7 Alumina Cup
  • 1 - Weldmonger #8 Alumina Cup
  • 1 - Furick Jazzy 10 Ceramic Cup
  • 1 - Furick FUPA 12 Ceramic Cup
  • 1 - Furick Moose Knuckle Ceramic #14 Cup
  • 1 - Furick BBW Ceramic Cup
We also have kits for 9/20 TIG torches
Navigator Ceramic Version for 9/20 TIG torches
navigator-ceramic-9-20
Navigator Clear Cup Version for 9/20 TIG torches
navigator-clear-9-20
We Several other TIG kits for practically every industry and application .
Visit weldmonger.com
