TIG ALUMINUM .063" 2f TEE 250HZ
scroll down for details and settings
2ftee-aluminum-thumb-smaller
A high AC frequency setting can help focus the arc and that can be helpful for fillet welds where penetration into the root of the joint is needed as is the case when testing to AWS D17.1
METAL TYPE = ALUMINUM 6061
THICKNESS =  .063"
WELD TYPE = FILLET
JOINT TYPE = TEE JOINT
POSITION = 2F
AMPERAGE = 90 AMPS ON MACHINE CONTROLLED BY FOOT PEDAL
FILLER WIRE = 1/16” 4043
POLARITY = AC
GAS FLOW = 15 CFH argon
CUP SIZE = 5
ADDITIONAL SETTINGS =   AC BALANCE 30% CLEANING, AC FREQ 250HZ
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
