TIG ALUMINUM .125" thick SQUARE TUBE 1G BUTT
METAL TYPE = ALUMINUM 6061
THICKNESS =  .125"
WELD TYPE = GROOVE WELD
JOINT TYPE = BUTT
POSITION = 1G
AMPERAGE = 140-160 CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4043
POLARITY = AC
GAS FLOW = 20 CFH argon
CUP SIZE =  8
ADDITIONAL SETTINGS =   AC BALANCE 30% CLEANING, AC FREQ 70HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
