TIG WELDING ALUMINUM .125" THICK EDGE BEAD
scroll down for settings
METAL TYPE = ALUMINUM 6061
THICKNESS =  1/8”
WELD TYPE = EDGE BUILDUP BEAD
JOINT TYPE = EDGE BEAD
POSITION = FLAT
AMPERAGE = 125 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4043
POLARITY = AC
GAS FLOW = 20 CFH
CUP SIZE =  8
ADDITIONAL SETTINGS =   AC BALANCE 35% CLEANING, AC FREQ 120HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
