TIG ALUMINUM .125" thick VERTICAL UPHILL TUBE BUTT
tig welding vertical or overhead usually means forgetting all the textbook instructions on rod feeding angles.  If it works, it works.
METAL TYPE = ALUMINUM 6061
THICKNESS =  1/8"
WELD TYPE = GROOVE WELD
JOINT TYPE = BUTT
POSITION = 3G VERTICAL
AMPERAGE = 120 CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4043
POLARITY = AC
GAS FLOW = 15-20 CFH argon
CUP SIZE = 8
ADDITIONAL SETTINGS =   AC BALANCE 30% CLEANING, AC FREQ 70HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
