TIG ALUMINUM 11GA AC BALANCE SETTINGS
check out the one page plan for tig welding aluminum
Simplified TIG settings using a Prime Welder aka PrimeWeld TIG225x
PrimeWeld TIG225x Best Settings Page
primeweld 225 tig with stuff
The problem with most other really affordable tig welders is usually a really cheap foot pedal and TIG torch.  Primeweld went to extra expense to include a genuine CK17 torch with superflex hose along with a very smooth SSC style foot pedal.
A high quality CK dinse adapter is also included so that you can easily swap out a tig torch or cable when the time comes.
Primeweld also has a responsive primeweld equipment users group on facebook and also has demonstrated great customer support
Watch some more primeweld videos and you will see what I mean.
METAL TYPE = ALUMINUM 6061 .120”
THICKNESS =  .120"
WELD TYPE = BEAD ON PLATE TO DEMONSTRATE AC BALANCE SETTINGS
JOINT TYPE = BEAD ON PLATE
POSITION = FLAT
AMPERAGE = 140 CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4043
POLARITY = AC 100 HZ
GAS FLOW = 15-20 CFH argon
CUP SIZE =  5
ADDITIONAL SETTINGS =   AC BALANCE SETTINGS OF 90, 80, 70, AND 60% EN SHOW LEVEL OF CLEANING ACTION
PRE FLOW = .2 SEC
POST FLOW = 10 SEC
TIPS: AC BALANCE ALLOWS SETTING THE LEVEL OF CLEANING ACTION.
MACHINES DIFFER SO AND SO DOES THE LEVEL OF OXIDATION ON ALUMINUM. SET AC BALANCE TO WHERE THERE IS A VISIBLE ETCH LINE AT THE TOES AND TO WHERE THERE ARE NO BLACK DOTS IN THE PUDDLE.
KEEP A FAIRLY TIGHT ARC AND WATCH TORCH ANGLE
