TIG ALUMINUM LAP .063" 400HZ
lanthanated-blue-tungsten-10pk
METAL TYPE = ALUMINUM 6061
THICKNESS =  .063"
WELD TYPE = FILLET
JOINT TYPE = LAP JOINT
POSITION = 2F
AMPERAGE = 100 AMPS ON MACHINE CONTROLLED BY FOOT PEDAL (HIGH FREQUENCY AC SETTINGS SOMETIMES REQUIRE MORE AMPS THAN LOWER FREQUENCY SETTINGS)
FILLER WIRE = 1/16” 4043
POLARITY = AC
GAS FLOW = 15 CFH argon
CUP SIZE = 5
ADDITIONAL SETTINGS =   AC BALANCE 30% CLEANING, AC FREQ 400HZ
PRE FLOW = 1 SEC
POST FLOW = 7 SEC
