TIG ALUMINUM 1/4" TO 1/8" LAP 2F
METAL TYPE = ALUMINUM 6061
THICKNESS =  1/4” TO 1/8"
WELD TYPE = FILLET WELD
JOINT TYPE = LAP
POSITION = 2F HORIZONTAL
AMPERAGE = 200 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 1/8” 4043
POLARITY = AC
GAS FLOW = 15-20 CFH argon
CUP SIZE =  8
ADDITIONAL SETTINGS =   AC BALANCE 30% CLEANING, AC FREQ 70HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
