TIG BRAZE CARBON STEEL 11GA CORNER WITH SILICON BRONZE FILLER - PULSE SETTINGS
METAL TYPE = COLD ROLLED STEEL
THICKNESS =  .125"
WELD TYPE = FILLET WELD
JOINT TYPE = CORNER
POSITION = 1F
AMPERAGE = 109 AMPS USING PULSE SETTINGS CONTROLLED WITH FOOT PEDAL
GAS FLOW = 25 CFH argon
CUP SIZE =  12
ADDITIONAL SETTINGS =    PULSE SETTINGS   1PPS, 30% BACKGROUND CURRENT, 50% ON TIME
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
