TIG CARBON STEEL 11GA OUTSIDE CORNER 2F
scroll down for details and exact settings used for this 1/8" thick carbon steel outside corner joint
Clear cups like the furick 8 pro help me see better by lighting up the weld area. The glowing tungsten inside the clear cup acts as a flood lamp.
Filler metal size for a .125" thick outside corner can be as small as .045" or as large as 3/32".  I used 3/32" er70s2 for this weld but it was a bit large for my preference. I usually go with 1/16" for this weld.
METAL TYPE = CARBON STEEL
THICKNESS = 11GA
WELD TYPE = Fillet weld
JOINT TYPE = CORNER JOINT
POSITION = 2F HORIZONTAL
AMPERAGE = MACHINE SET TO 115 AMPS
FILLER WIRE = 3/32" ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  8A
DDITIONAL SETTINGS =
PRE FLOW = 0.5 SEC
POST FLOW = 8 SEC
TIPS: KEEP A TIGHT ARC
