TIG CARBON STEEL .125" WALL THICKNESS EDGE BEAD BUILDUP
scroll down for exact settings used
An edge bead is sometimes used to restore dimensions to a part that has worn or was mis machined.
Sometimes multiple beads are needed to achieve final dimensions
Edge beads typically take a lot less amperage than any other weld...often only about 20-50% of what it would take for a fillet weld on same thickness ( depending on metal type)
METAL TYPE = CARBON STEEL TUBE
THICKNESS = .125” WALL THICKNESS 1 INCH TUBE
WELD TYPE = SURFACE EDGE
JOINT TYPE = EDGE BUILDUP
POSITION = FLAT
AMPERAGE = 50-65 amps with foot pedal
FILLER WIRE = 1/16” ER70S6
GAS FLOW = 25 CFH argon
CUP SIZE =  12
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
