TIG WELDING CARBON STEEL 1/4' WALL TUBE PULSE SETTINGS FILLET WELD ON TURNTABLE
METAL TYPE = CARBON STEEL
THICKNESS = 1/4” WALL THICKNESS TUBE TO END FITTING
WELD TYPE = FILLET
JOINT TYPE = FITTING INSERTED INSIDE TUBE
POSITION = ROLLED ON TURNTABLE
AMPERAGE = MACHINE SET TO 210 AMPS USING PULSE SETTINGS
FILLER WIRE = 3/32” E70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PULSE SETTINGS 2 PPS, 60% PULSE TIME, 60% BACKGROUND CURRENT, 1 SECOND UPSLOPE, 5 SECONDS DOWNSLOPE
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
