TIG STAINLESS STEEL EDGE BEAD ON .050" THICKNESS
THICKNESS =  .050"
WELD TYPE =  EDGE WELD
JOINT TYPE = EDGE
POSITION = FLAT
AMPERAGE = 15-18 AMPS.
MACHINE SET TO 30 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = .045” ER308L
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
