TIG WELD ALUMINUM BUILDUP EDGE BEAD ON 1/4" THICKNESS
Scroll Down for Details and Settings used
If you are like me, you mostly use 3/32" tungsten but sometimes need 1/16" or 1/8". This bundle gives you what you need.
A 10 pack of 3/32" along with 3 packs of 1/16" and 1/8".
Learn more at Weldmonger.com
METAL TYPE = ALUMINUM 6061
THICKNESS = 1/4 INCH
WELD TYPE = BUILD UP SURFACING
JOINT TYPE = EDGE BUILD UP
POSITION = FLAT
AMPERAGE =200 AMPS CONTROLLED WITH FOOT PEDAL (ACTUAL PEAK AMPERAGE 105-110
FILLER WIRE = 3/32” 4043
POLARITY = AC
GAS FLOW = 20 CFH argon
CUP SIZE = 8 GAS LENS
ADDITIONAL SETTINGS = AC BALANCE 33% CLEANING, AC FREQ 50HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
TIPS: KEEP A FAIRLY TIGHT ARC AND WATCH TORCH ANGLE
var l = window.location.href,
d = document;
