Tig Welding Aluminum 11ga 3G butt joint full penetration settings
scroll down for settings
METAL TYPE = ALUMINUM 6061
THICKNESS =  1/8"
WELD TYPE = GROOVE WELD
JOINT TYPE = BUTT
POSITION = 3G VERTICAL
AMPERAGE = 130-140 CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4043
POLARITY = AC
GAS FLOW = 12-15 CFH argon
CUP SIZE =  5
ADDITIONAL SETTINGS =   AC BALANCE 33% CLEANING, AC FREQ 90HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
TIPS: KEEP A FAIRLY TIGHT ARC AND LIMIT TORCH ANGLE
