TIG WELDING ALUMINUM 1/4" THICK LAP JOINT AC ADVANCED PULSE ALTERNATING BETWEEN DC AND AC
scroll down for list of settings
METAL TYPE = ALUMINUM 6061
THICKNESS =  1/4”
WELD TYPE = FILLET WELD
JOINT TYPE = LAP
POSITION = 2F HORIZONTAL
AMPERAGE = 200-250 AMPS ADVANCED PULSE CONTROLLED WITH FOOT PEDAL
TUNGSTEN = 2% LANTHANATED, 1/8"FILLER WIRE = 1/8” 4943
POLARITY = AC USING ADVANCED PULSE AT 2PPS ALTERNATING BETWEEN AC AND DCEN
GAS FLOW = 20CFH
CUP SIZE =  8
ADDITIONAL SETTINGS =   AC BALANCE 30% CLEANING, AC FREQ 77HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
