TIG WELDING SETTINGS - ALUMINUM 11GA  CORNER JOINT
scroll down for settings
METAL TYPE = ALUMINUM 6061
THICKNESS =  1/8"
WELD TYPE = FILLET
JOINT TYPE = CORNER
POSITION = 1F
AMPERAGE =120-130 AMPS  CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4943
POLARITY = AC
GAS FLOW = 15 CFH argon
CUP SIZE =  5
ADDITIONAL SETTINGS =   AC BALANCE 33% CLEANING, AC FREQ 120HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
