TIG WELDING ALUMINUM 1/4" THICK PADDING BUILDUP
Padding beads on aluminum is a great way to get better at tig welding.
Its the same skill used in build up on worn or mis-machined parts.
If you practice this drill, I promise that you tig welding skills will improve for all metals.
A #5 standard cup works well for this drill but a clear #8 pro cup lets me see better.
METAL TYPE = ALUMINUM 6061
THICKNESS = 1/4 INCH
WELD TYPE = BUILD UP SURFACING
JOINT TYPE = BUILD UP
POSITION = FLAT
AMPERAGE =200 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4043
POLARITY = AC
GAS FLOW = 20 CFH argon
CUP SIZE = 8 GAS LENS
ADDITIONAL SETTINGS = AC BALANCE 33% CLEANING, AC FREQ 50HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
TIPS: KEEP A FAIRLY TIGHT ARC AND WATCH TORCH ANGLE
var l = window.location.href,
d = document;
