TIG WELDING ALUMINUM TUBING .120" wall thickness
I used a clear #8 pro cup with 20 cfh of argon and a 3/32" (2.4mm) 2% lanthanated tungsten.
Using miller dynasty 280 basic pro settings of 70% ac balance and 120 hz on ac frequency.
Machine was set to 140 using the foot pedal.
scroll down for settings
METAL TYPE = ALUMINUM 6061
THICKNESS =  1/8”
WELD TYPE = COPED TUBE JOINT
JOINT TYPE = COPED TUBE PARTIAL PEN
POSITION = FLAT
AMPERAGE = 140 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” 4043
POLARITY = AC
GAS FLOW = 20 CFH
CUP SIZE =  8
ADDITIONAL SETTINGS =   AC BALANCE 30% CLEANING, AC FREQ 120HZ
PRE FLOW = 1 SEC
POST FLOW = 10 SEC
tig-aluminum-tube
