Whether you are a student, hobbyist, or a working welder who wants to sharpen up, you can take a free trial and even get 25% off your first 3 months with promo code QS25.
METAL TYPE = CARBON STEEL TO STAINLESS
THICKNESS = WALL THICKNESS 1/4”
WELD TYPE = Fillet weld SOCKET WELD SECOND PASS
JOINT TYPE = SOCKET WELD
POSITION = TURNTABLE
AMPERAGE = 140 amps
FILLER WIRE = 1/8” ER309
GAS FLOW = 20CFH argon
CUP SIZE = 6
ADDITIONAL SETTINGS = PRE FLOW = .5 SECPOST FLOW = 11 SEC
TIPS: KEEP A TIGHT ARC
